I just got a new OER windshield header molding set to replace the existing one on my 68 conv. I read in some old posts there are fit issues with some of the reproduction parts. Has anyone used the OER moldings that could comment on the fit? Will I need to pull the window trim chrome to remove the header molding, and/or do anything with the window seal? I had removed the header screws and visor mounts but the header molding wasn't budging easy. I didn't want to start prying things off so I stopped.
I tried to use aftermarket header moldings. I think they were OER brand from Classic Ind. They fit so bad I purchased a set of used ones with some rust insted of using them. Even with a BFH I could not get them to fit even close to acceptable. This is on my 69, a 68 may be better. My .02
I had my old ones replated, they did a sort of brushed nickel plate to closely match the satin finish...cost me if I recall about the same as repops and of course fit great as they were the originals...there was a few rust spots on them but the plating shop fisxed up the spots first for the price.
I would like to have my originals plated as they have some minor pitting / rust , any ideas about the best shop . I have mine off the car and i'm using some repops not glued down in the front so I can get them back off easy ! - The repops fit terribly by the way !
Think I am going to redo mine in bright chrome and change out the sun visor brackets also. Will be easier to upkeep and looks better anyway. I have no experience pulling these off, do they sit in front of or behind the actual windshield glass? What type of glue or sealant is used , and is mainly for weather seal or holding the trim in place?
I don't know what held it on, if anything, other than the screws, but it was a bugger to get off. Best sequence I don't know, as we tore the entire car down.
thewy are attached (originally)with some black mastic....t get them off use a hair dryer or such to heat up and slowly!! pry them off...they sit on top off everything else, just take the 5 screws out.
... I have no experience pulling these off, do they sit in front of or behind the actual windshield glass?...
Neither, next to it. The moulding slips over the windshield frame with the short edge just turned down over the metal windshield frame. Then the windshield mouldings butt-up against it to cover the area where the sealant is.
