maybe someone out there remembers forum about stripping old paint off parts and also removing rust? I remember it was some sort of acid that could be purchased at home depot. thanks for help
I use this stuff called Rusteco. Its not acid, so it doesnt harm the metal. It is also non toxic so you can get it on your hands. It has been working pretty darn well for me. Check www.rusteco.com
If the parts are small, there's also a way to do it electrolyitcally with a plastic bucket, some washing soda, a small sheet of stainless steel and a battery charger...
Yes! Thanks, Q! I meant to infer the "navel" spelling, and that's what I meant about being too vague, I should have just used "navel". And just to finish off what I thought would be a clever retort, lipids are, basically, what our bodies store energy in: Fat! So I was referring to what us Norwegians would call a "yelly belly"! I'll try to take it back a notch or two.
TOHCan, you seem like a smart guy. I have to admit you were the only guy who recognized that I misspelled "ignorance." However, I am pretty sure you meant to imply, so that we'd all infer ... not the other way around. Check out a Dennis Quaid movie called "DOA."
And here I was thinking you meant the lipid based oils that do not dissolve in water, such as, perhaps, Vasoline ... (though I admit I think that one is in fact petroleum based and not lipid based. But, what do I know? I'm not a biochemist.)
Oops! Got me on that one! I sit corrected! Oh, the implications! I guess I should leave the inferences to others from now on. And I'll admit, the biochem stuff is mostly Greek to me!
