Definitely the door panels. Very difficult with the glass still in, but with the right offset tools, can be carefully done.
It's a whole lot easier with the glass out, but that's a project in itself.
The screws holding the weatherstrip in are horizontal, and are somewhat below the top of glass line when the glass is all the way down. The middle portions of the weatherstrip are held in with clips, while the ends are screws.
good luck.
When installing the weatherstrip with the clips, put some masking tape (2 layers) on the door....I slipped with one as i was working in the clips and put a 1/4" scratch in my brand new paint....
You might just be able to remove the two nuts on the window lower horizontal track and gently lower the glass down to the bottom of the door enough to have some more working space....
