Does anyone know where I can order the two traction bar bushings for my 67 bird. I have the single bar located on the rear passenger side. I found some on p-s-t.com listed as - Polygraphite Right Side Traction Bar Bushings 1967.
However, when I called and spoke with a rep. I was told that both bushings were the same size. I have the bar off of the car and the front bushing is definately much smaller than the rear one.
Does anyone know where I can order these, or maybe what size they are. Any help would be appreciated!
PST is wrong about that. Get the correct bushings from Energy Suspensions. They are listed under the Camaro section as 67 Rear Traction Bar Bushing Set.
