I'm starting to put my bird back together. Yesterday, I pulled out my window regulators and window guides out of the boxes. I messed around for about an hour trying to figure out how the 3 stud type bolts hold the guide on? Does anyone have any photos or advise on how to install rear window reg and guide?? I have a service manual but It really doesn't have detailed photos?
I looked, but didn't take any pics of putting them in. DO you have the Fisher Body Manual? There are some fairly good drawings in there. But, as I recall, the the three stude screw into the track and the end with the large washer on it butts up against the back side of the body framework, with a nut on the inside. You can turn the stud with the screw slot to adjust the window position. (2 studs to the bottom, 1 to the top.)
This is the best part of a pic of mine when it was open....Lee is correct, but have done a sketch of what he is trying to say for the studs. Hope this helps a bit.
That is exactly what I need to see Dave!!! It's been over 3 years since I took the glass out?? I'll have to post some pics of the Bird. It's looking really good!
