I believe it is......actually I prefer my drop top over the power one.....I rarely use it anyhow, and if it needs to go up in a flash rain, it's up in seconds.....
I have the manual top parts now (top frame going back together) and I have a spare set of power top side rails. They will need some work due to abuse on a manual top car, though they are not rusted or broken or bent.
'67-68-69 Camaro and Firebird top frames appear to be the same. Power top frames have several components (all bolt to the side rails) that are different than a manual top. If you find a pair of good side rails with their attaching brackets and links you are good to go.
side view difference in power and manual top frame , courtesy of Jim2002 left is power , right is manual... see the brace at the elbow on the left one?
