Posts: 538 |
I have a lot of slop in my 69 with a manual steering box. Is there any adjustment I can do to get the play out? If not, what's the best route -- get the box rebuilt or buy a replacement? Any referrals on a replacement?
Thanks!
John
Posts: 9,027 |
Have you checked the tie rods and pitman joint. I had quite a bit of play in mine and found the pitman arem was shot. Replaced it and tight as a drum.
Posts: 856 |
To check steering box (If all other steering parts are tight)just take steering wheel lightly in hand and rock it back and forth while watching the front wheel. The wheel should move at the same time as the steering wheel. If there is play you addjust the box by the allen headed screw on top of the box. Lossen the lock nut and turn allen screw in a little then check steering again.
Be carefull not to go to far. It will cause a binding in the steering wheel if you do.
Posts: 538 |
All new parts for the rest of the suspension, except for the box.
Jim, someone else told me about trying to adjust the box as you've described. Sounds pretty easy -- I'll give that a try!
Thanks,
John
Posts: 251 |
Make sure you do that ajustement in straight ahead position as the center teeth is slightly bigger
1 members (Dr. Drivability),
1,839
212
