Posts: 317 |
Long while back there was a topic on this but I can't find it. I have stock non-power drum brakes all around, instead of putting on a disc brake kit for now I'd like to just add a power booster. On the previous thread I thought it was said the only thing you'd need for that is a longer push rod that goes up inside the booster, is that right or would I need something else?
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
You'll be moving the master cylinder forward requiring you to relocate the brake lines...usually doesn't come out very well and you may end up replacing them...not a bad idea for a 40 year old car. I gotta say, I had that setup and went to front power disc and I've been driving this thing like crazy! What a difference. You should be able to get a front disc conversion kit for 700-800 with all new lines and everything you'll need.
On a scale of 1-10 in difficulty, I'd rate it a good 6-7 depending on your ability.
Good luck with whichever way you go!
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
I just finished this conversion this week. (or should I say my mechanic did) I my case we were replacing all of the brake lines so we ordered a pre-bent set and everything fit pretty well. He did mention that there was something about mounting the lever arm lower or through a lower hole or something like that. He had to take it off the firewall once because of that, but everthing else worked fine.
Posts: 6,341 |
When I bought my car it had manual brakes. If I remember correctly all I did was unbolt the m/c from the firewall and gently pulled the m/c with brake lines attached and all, dropped the booster in place, bolted it in and reconnected the m/c to the booster. The reason I beleive I was able to install the booster without removing the m/c was the fact that the entire project was very quick. I remember being shocked at just how quick the whole thing went. The other odd thing I remember was installing the longer (or shorter) push rod then ultimately going back to the original one. All in all it was a very easy project and resulted in huge benefit. IMO power brakes and power steering are a must!
Posts: 317 |
Hmm, after checking prices on a full upgrade kit I may just do that. The smaller duel diaphragm boosters I was looking at run close to $200 wit shipping, the Matts Bow Tie full upgrade runs about $450 and has everything but the pre-bent hard lines.
Posts: 7,719 |
68 Firebird 400's method is actually not so strange.
In fact, it follows how the factory built the cars. The brake lines were installed onto the subframes along with the M/C hanging in the air until the body was dropped onto the subframe.
In fact, it follows how the factory built the cars. The brake lines were installed onto the subframes along with the M/C hanging in the air until the body was dropped onto the subframe. True, but the master cyl and the lines were already in the correct position for the application.
Posts: 6,341 |
I'm not saying the way I did it was the correct way, but it worked. LOL I eventually did end up changing out the m/c about a year later as I wanted the dual bail wire style to make it correct looking, otherwise it worked out fine...
Posts: 3,889 |
I put a booster on my cammer in the same way. You just have to be careful pulling the master cylinder forward, so you don't pinch any lines. My friend Pat did the same thing with his '67 'bird.
2,110
46
