Ok...both windows..passenger and drivers side are loose..noticeable when they are say half way down. I can wiggle them back and forth. I realize the door compartment will have to come off to fix this. Just wondering which parts I will need....any advice appreciated.
there are two felt pads on brackets on top part of the door that keep the window from moving they are loose. they have screws that when losen will set the pads. also the windows have two roller bearings on a bracket attachet to it they can also be worn
