I am trying to get my vacuum lines all in the right place and I can't find a reference that shows the proper configuration? I even bought the 1968 Firebird/Tempest shop manual but it does not show the config. I have an all stock 1968 400 V8 with automatic transmission, power brakes/steering, 4bbl quadrajet. Does anyone know where I can see a picture or diagram that shows proper vacuum hose placement for my setup?
In case you did not know about the wealth in info on the '68 Firebird Restoration site - now you know.
I believe you can still send the site owner some $$ and he will send you a CD of all his info. He's a member here.
Thank you very much! I was able to hook almost everything up from that diagram. The only things not hooked up are the hose to the power brake assist pump and the vacuum line to the automatic transmission. Does anyone know where these hook up? Thanks!
