The passenger side headlights on my 68 coupe are out when I go to high beam. The low beam lights work fine, although appear weak. Replaced high beam light, but problem still there. Did research. Do I need to install relays and/or do I have a short? Where to look?
That's what I like about Vikki, to the point! There are 2 ground connections in the headlamp harness both go to the radiator support start you investigating there.
Thanks, checked grounds, both are secure to radiator support. I'll try the low beam (these lights are fun to put back together)and see if anything is loose or cut.
