#16967 05/14/04 03:23 AM
I have a 1968 Firebird with a 350/350 2bbl car combo i think? my car is a column shift car it has 3-speed what other tranny could it be??? i hear alot of people say that they have a 350 2bbl car like mine but have a 2-speed tranny i.e power glide so that is why i am wondering if my car came that way factory?? Is this possible ? and my last question is when i hear people refer to transmissions they use the term BOP what is that?? will A 350 trans from a chevy bolt right in?? oh yeah and i remember doing a burn out and both tires were painting the floor it has a posi could it be possible that a 2bbl 350/350 265 hp car have a posi??
thanks guys appreciate all the help,
joe
"Live and let live" matching #s 68 firebird
#16968 05/14/04 03:28 AM
Q
Q Offline
If the shift indicator on the steering column has a "2" in it, you have a TH350. If it has a "S" in it, it's aTH400. (I think, but don't hold me to that!)
BOP stands for Buick/Olds/Pontiac.
A chevy TH350 will NOT bolt straight in.
Posi was available for any engine/carb/trans/rear gear combination.
Q
#16969 05/14/04 03:44 AM
T Offline
According to my book, Chev and Buick use L2 and L1 on their shift quadrant, and Pontiac and Olds use S (for Super, not second) and L (Low).
#16970 05/14/04 05:44 AM
i can also just check the transmission pan right? i just wanted to make sure that it was a possibility everything it has could have come from the factory!
thanks guys
#16971 05/14/04 05:54 AM
T Offline
Yes, a TH350 has a pan that is almost square with one corner cut off.
#16972 05/14/04 01:08 PM
If you really want to know how your car came from the factory get the build sheet from PHS. $35 will save you a lot of guessing. There could have been some changes made in the 36 years.
#16973 05/14/04 03:55 PM
I didn't think you could get a TH350 in 1968, only a TH400? I also believe all 350 engines with autos in 1968 with column shift came with the 2 speed auto only. TH400's required floor shift.
http://firstgenfirebird.org/firebird/1968/sales_manual/N-3.html
You really need to look at the tranny pan to see what you have. Here is a link to the different shapes:
http://www.maliburacing.com/auto_tranny_id.htm
And for the Pontiac 2 speed (ST-300 not Powerglide) that came in our Firebirds:
http://www.autotran.us/gmABpg26.htm
Hope this helps,
G.J.
68 350 Coupe
GJ
68 350 (now 474ci) Coupe
https://photos.app.goo.gl/Xk5RdwNYt1vV7Cm86
