I have a 1968 Firebird with a 350/350 2bbl car combo i think? my car is a column shift car it has 3-speed what other tranny could it be??? i hear alot of people say that they have a 350 2bbl car like mine but have a 2-speed tranny i.e power glide so that is why i am wondering if my car came that way factory?? Is this possible ? and my last question is when i hear people refer to transmissions they use the term BOP what is that?? will A 350 trans from a chevy bolt right in?? oh yeah and i remember doing a burn out and both tires were painting the floor it has a posi could it be possible that a 2bbl 350/350 265 hp car have a posi?? thanks guys appreciate all the help, joe
If the shift indicator on the steering column has a "2" in it, you have a TH350. If it has a "S" in it, it's aTH400. (I think, but don't hold me to that!)
BOP stands for Buick/Olds/Pontiac.
A chevy TH350 will NOT bolt straight in.
Posi was available for any engine/carb/trans/rear gear combination.
i can also just check the transmission pan right? i just wanted to make sure that it was a possibility everything it has could have come from the factory! thanks guys
If you really want to know how your car came from the factory get the build sheet from PHS. $35 will save you a lot of guessing. There could have been some changes made in the 36 years. Jim
I didn't think you could get a TH350 in 1968, only a TH400? I also believe all 350 engines with autos in 1968 with column shift came with the 2 speed auto only. TH400's required floor shift.
