can anyone tell me where, or better yet show me a picture, of where the line from the vacumm canister inside the drivers side fender goes. Mine are not connected and i hate crawling over the new paint looking. Thanks in advance for the help guys.
You can always install a T on a manifold vacuum line. Readily available at any auto parts store, along with the tubing. Take a piece of existing tubing in with you after test fitting to the vacuum canister. The ends will be a little stretched on the old tubing so you may need to snip a little off to get a good seal on the tee.
