Converting from a PG to a TH400 does the crossmember need to be changed? When pairing up the 2 transmissions it looks like the TH400 is slightly longer than the PG. Will the TH400 fit without changing anything?
Ya, you're right, I guess it is electric, I couldn't remember all the facts, check out this link (from this website), it tells you everything, just scroll down to the 400 conversion.
I read the F.A.Q. about the trans swap. It doesn't specify if you have a long tail or short tail transmission. I have a TH-400 with a short tail. There is only about an inch different in length between my PG and TH-400. I understand I have to change the yoke, but do I really need to change the shaft too?
