69 400 cooling system insert removal help
172248
07/31/09
10:59 PM
Jul 2009
San Francisco bay area, Califo...
HighlandLassie
HighlandLassie
Jul 2009
I have a 69 400 and am replacing the water pump and the plate.
There are tubular inserts in the timing cover that need to be replaced.
I have the parts, but do not know the best way to remove the old inserts.
Do you have to remove the whole timing cover, or is there a way to get them out from the outside?
Any help apprecieted!
Thanks,
07/31/09
11:00 PM
Re: 69 400 cooling system insert removal help
HighlandLassie
172262
08/01/09
12:24 PM
Sep 2000
WI
RossettiJ
RossettiJ
Sep 2000
WI
Once the water pump is off and the plate is removed, the inserts are free to come out. They are not bolted, fastened,or glued. Right now they are probably held in place with scale or rust. Tap on them. They should probably fall out.
John
RossettiJ
172415
08/03/09
04:27 PM
Jul 2009
HighlandLassie
HighlandLassie
Jul 2009
Thanks for the tip,
They must be really stuck in there good, they would not come out.
I chose to grind out the old rubber with a dremel tool and just replace the rubber ring instead.
08/03/09
04:32 PM
1stgenbirdman
0 members (), 441 guests, and 12 robots.
