I had the same thing happen to mine, and I was able to glue the two pieces of glass back together with a clear Aquarium sealer, which I purchased at a local hardware store. Not sure if your's split like mine down the bead that hold the two pieces of glass together, but it sure did the job.. I placed a piece of flat wood on the inside of the window, ran a tape on the inside bead and spread the sealer on the bead through the outside. I let it dry and the next day I trimmed the extra sealer off with a razor blade. It held perfect...Just like it was new..
Carlos 1967 Coupe 326 1967 Conv.326 carlito121@msn.com
I read the same on some of my other cclassic forums. Seems like this fix has worked for many. Did you take off the origional bead and seal galss to glass or the bead to bead?
