Will it fit? will it help direct air to raditor? I think I have seen it done in the past.. and yes I know that is not orginal...just need something to direct airflow.. Thanks..
The Camaro spoiler wasn't designed to direct airflow to the radiator, it was for downforce.
If you need more air into the radiator, I suggest the factory lower baffle pan that was used on the Firebird 400 cars, and the two upper baffle panels that go between the core support and the front bumper panel. These 3 pieces are all reproduced now in steel (you may be able to still find the fiberglass versions if you're not concerned with numbers matching), and they will force more air into the radiator that comes through the valence panel and grilles.
I have the two upper panels, do any of the vendors carry the lower panel? I dont see anything on the assembly manual either? Can someone point me to a lower baffle that was used...thanks
Used ones show up on Epay or Craigslist from time to time. I do not see any at either site right now though.
wasn't there a couple in the parts for sale section recently,like last week or two.they are repoed in fibreglass.they go fast on ebay up to $2-300.check Franks pontiac parts,i got one from them a few months ago for $75.
if you drive over 80 , 85 MPH it will help get better steering ,keep the front wheels on the ground....both front and rear Camaro spoilers help to get ground force....I have both... read this article... http://www.camaro-untoldsecrets.com/articles/rpo_d80.htm
