How much more horsepower than the edelbrock will an 068 pump out in a 400+.060, with 670 heads, Carter 625AFB, stock log manifolds, 3.42 gear, TH350? Maybe 10 or 15hp? Or is it more like 50hp. i.e. is it worth the change? Engine runs pretty good with the edelbrock. No pinging, good idle, good low end torque.
Thanks for the input. I'm new to hot rodding engines...but I've been reading about this stuff since I was a kid.
I guess I'll leave the cam alone (especially since the engine is back in the car now).
Maybe rather than cam, I should port the exhaust on the 670 heads since I'm running more than .400 lift. Any comments on this?
I might try a bigger carb, but the CFM calculations assuming 90% volumetric efficiency tell me 600CFM is enough. So, I'm a little confused about this, but I don't know of anybody running a carb that small on a 400 plus cube motor.
The car runs pretty good now, so maybe I should just leave it alone.
