It should fit fine, but you may need to extend the marker light wiring. All that is different is the lower valence, marker lights, and fender lowers. Hood latch mechanism is also different, but if you change out the entire '67 mechanism into the '68, it will work.
Don't attempt to switch out the doors though. That would be a painful modification.
Since I don't know enough about 68's yet. What do you mean it won't look correct? I have a 68 lower valence I can swap out. My original hood has some big dents, so I was thinking of using this one since it is nicer. All I really need it for is the fenders, and radiator support. The fenders that came with the car are way to far gone to repair. I have heard about the latch and I am looking for one for a 68. Thank you for the help and info!
1968 Verdoro Green 350 2bbl 3speed Hurst on the floor.
In that case yes, you should be able to piece it together using much of the 67 parts (fenders and hood) and as long as you have your hood latch with the safety catch from the 68 you can use that and could change out the receiver section of the hood if needed...
All in all, it should work out fine. Sounded like you intended on swapping the full front clip with a 68 body etc... which would be noticeable to most car people is all...
Especially if you can get a good deal on the parts... anything is possible!
