i see a fuse marked hazzard,but were is the switch on a 68'. and are the door courtesy light on the same curcuit as the brake lights. thanks for any help tim
Are you asking where the switch to turn the hazzards on is located? If so, it is on the steering column on the right side. It's just a button that you pull out, then push back in to turn them off...
