How the heck do I get the ignition lock cylinder outta the dash? The bezel unscrews most of the way and then seems to bind up. It's getting pretty tense out in my garage!
Jake,you have to first remove the cylinder from the ignition then unscrew the bezel. put the key in the ignition and turn it left i believe (if not-right then) and insert something small into the tiny hole you see and push in on the thing you put in the hole,then pull out the cylinder.Then you can unscrew the bezel. Good luck David.
