I have Dougs headers on my car. They do not hang any lower than the subframe rails. They are almost too close to the floor, so good thermal floor insulation is a must.
Better count on buying a new starter too. The old one might start to give you heat soak problems from the extra heat the headers will cause. Just something you might want to budget in.
I don't think Doug's headers are "short". They're just designed to fit a bit closer to the undercarriage...
Bingo. They also clear the PS unit and oil filter well, so overall the general consensus is they fit better than other headers.
