Does anyone have a diagram or pictures of how the headlight assembly goes together? Mine were never complete when I bought my 68, so all I have is a pile of lamps, buckets, brackets, cage nuts, adjuster screws, and trim rings. The shop manual doesn't have the specifics, so any help would be great.
The buckets/lamp combos are not interchangable. Low vs high beams have different notches on the back of the bulbs and, IIRC, the buckets are stamped left and right.
And I had some kind of issue with the adjuster springs as in whether they just hooked over the buckets or into tangs on the trim rings. I can't remember which is correct at the moment.
I popped into the garage and double-checked (front grils not on yet). Adjuster springs hook through slots in BOTH the trim rings and buckets.
