Thanks, I should and did already know this before my health issues caused memory problems so here goes. 68 350 with the 2bbl carb. The dist vacuum advance live connects to where on the carb? Above the base plate or below? In the back on the carb there is a fitting with two tits. One goes to the transmission and the other (smaller one) goes where? Had carb rebuilt buy a fine shop, and had them check it again because I can't get it to idle down. The just tore it apart again and started over, and it still will not adjust. They told me to be sure I have it connected right. Looking in my shop manual and the Chiltons I see nothing aboout vacuum hose locations which is silly since it's part of the system. Any help, will get you many wram and kind wishes. Good day friends. Mike: rr67gto@aol.ccom
