HI, For a winter project I have a new wiring harness for the rear tail lights etc. Has anybody replaced theres and do you have any tips, gotcha's etc. Does this plug in at the fuse box or is there an intermidiate connector. thank you.
The rear light harness plugs into the main wiring harness near the fuse panel above driver's side kick panel (up front). There is a large plastic plug with a snap lock.
The beginning of the harness runs in a "cable tray" just inboard of the rocker panel then to the side of the rear seat divider and over the rear wheel arch.
Good to know the '69's are different. Thanks Vikki.
I finally ordered a tail harness for my '69 with the full harnesses for my dad's '68, and swapping my harness was 10 minutes, installing his tail harness in a bare shell was more like 30 minutes.
