Hey Gang, got an issue with my 69 bird. The automatic shifter is very sloppy in this car. The cable has no free play that I can tell and is tight but the shifter travels almost 2inches before the car shifts gear into reverse/neutral/drive and is real tight. it does not move easily between gears. Any suggestions? Are there any bushings in the automatic shift setup or am I looking at a old cable freezing problem?
