Hey guys, Happy 2010! I took a sanity break from cars for awhile, and am getting back to it. Bought this 67 400/4spd a few years back, had a Holley double pumper on it, ran terrible. Found a stock manifold; and a Qjet from a 69 400/4spd. Ran good, except the choke assembly (aftermarket for 67) didn't hook up with the 69 carb. Few more vacuum ports on the 69, as well as a different throttle arm. Anyway, it ran good, but I got tired of having no choke.
Found on ebay a service replacement rebuilt Qjet with no numbers, supposedly the same as a 7027273, which I refuse to spend $1200.00 on.
So, to the questions: 1. How do you connect the choke linkage? I'm not even sure I got the right one from the supplier, but the arm is way too long, and doesn't have a clip like my 67 327 Camaro 2. There are only 2 vacuum ports on this carb, one big one on the passenger's side front, and a small one on the driver's side front. At idle, the smaller port (about the same size as the distributor advance) pulls no vacuum. The larger port does, but again it's adifferent diameter from the dist. advance line. 3. Throttle return spring. What bolts onto the manifold to hold the spring? I rigged something up, but was wondering if anyone has the right part(s) or could point me to the aftermarket. Thanks!
Tom
1967 Camaro Convertible 327/275 with PowerGlide 1967 Firebird 400 Coupe 400/325 with 4-speed
You'll need a 67-70 throttle shaft for the qjet. I see repops for $79 that come with the choke linkage. You probably will also want the throttle extension that bolts on the new shaft (Ames has them).You also need the bent vent (one only) choke pull off, they run about $49 on epay. They have the short shaft and are metal. The throttle return spring attaches to a bracket that bolts onto the intake on the drivers side just aft of the carb. It also doubles as a wire loom. I dont see those aftermarket (im looking for one also) so you'll need to make something up. If you change out the throttle shaft, make sure you grind off the staking on the butterfly screws or they will break off.
