Does anyone recognize the missing wires in the following photos ? This is a 69' Coupe, no A/C, 350, Auto. There are 3 photos (3 questions). Thanks !!
1st photo: 4 wires coming off the fuse box (on the inside of the car), 3 of them go to the high beam switch, the other is brown and cut, any ideas what it goes to (it looks factory).
2nd photo: harness for front headlights, parking lights, side markers, horns, and one black wire cut coming out of the center (next to the plastic mounting clip), any ideas what it goes to (it looks factory).
3rd photos: harness part that goes under the dash, has a black connector off of it (5pin connector) with a 3pin connector that plugs into that (two of those pins are populated with a yellow and gray wire) the other two pins of the 5pin connector had one wire populated but the wire broke off and only the terminal is left, any ideas where that wire would go to ? Does it somehow connect up to the other wires shown (brown wire may go to the heater blower motor, and the other clear connector???)
Thanks for taking the time to help out !!! Or if you have a schematic I maybe can figure it out..
i have the front of my 69 coupe off ,the 2ND photo- the single wire if i am looking at it correct should be to the horn . my bird has 2 horns the other horn has 2 wires into a single plug.
Thanks alot ! I looked and understand that part now. For that 2nd photo, do you know where the two "eyelets" attach to ? Each of the two are near the left and right headlight connectors so they maybe attach to the front-end somewhere as grounds ?
still welcome responses to the 1st and 3rd photos...
ok, I was thinking that it went out the front firewall because of the grommet (but could not find a connection for it), never thought about it going out the back. I assume it attaches somewhere to the harness in the trunk ? Maybe next to the license plate light connection ? Thanks..
So then that gray wire with the clear plastic connector is for the factory radio ??
