My 68's front bumper does not seem to be aligned correctly. There is a big gap on the side and the head light panels have a gap. Can I email a pic to someone so you can get a better Idea of what I'm talking about. (unable to post pic on here). Not sure if my bumper is slightly warped or if its out of alignment.
You'd have to define "big gap". There is typically about a 5/8" to 3/4" gap around the sides. There are vinyl 'fillers' that bolt to the fender and bumper for '68. '67's had vinyl fillers too, with the early '67's having metal.
You can look at some close up shots on my photobucket for comparison.
If you want to email some pictures, you can send them to me at vike108@yahoo.com.
Craig
Usually its just an alignment issue....takes a bit of work to get it right. I still have a little work to do....got it closer using the jack and another buddy to tighten the bolts. I also recall shimming one of the braces with a washer to move it to the left where needed.
Word of wisdom, tape the painted surface of the fenders first...does not take much to get an ouwey....I did when I first mated the two together, 4 days after the paint job....ouch that hurt
I have about the 5/8 gap between the bumper and the front of the fender. I had the whole thing tore apart to the radiator core. I assembled most of the bumper assembly on the floor. When I was ready to re-install I basically hung the bumper from the insulators that are threaded on both ends and have the rubber between them. Once I got it settled from side to side I swung the assembly back to attach the bumper brackets to the frame. I had never done anything like this before, but when I did it this way it made it a bit easier for me. I was able to do most by myself.
