Which explains why you have the newer motor mount setup that does not work for FGF's.
Adapter plates or drill and tap the other two holes. I would leave the latter choice to a machinist.
If you have the 77 engine brackets and mounts, you can use a 3/16" "sandwich" plate between them and the 1st gen's frame and braces. Thats how i did mine.
I've got it done I work in a tool and die shop for Arctic Cat.Check out this drill templat that I made. I've got two sets of bushings that drop in the holes.One to guide the drill and one for the tap.It worked perfect, just as striaght as if I put the whole block in the mill and it only took about 15 min with a hand drill and tap wrentch.
