Without the block casting number it could be anything. Casting number is on pass side back edge of block near where the tranny bolts up to it. What are the heads casting numbers?
The number above the YT is the engine unit number. It can generally be found on the matching PHS. There is also a VIN down next to the timing cover behind the lower radiator hose.
The 1st letter is for either auto(Y) or manual(W) trans. 2nd letter?...maybe for type of engine build like cam with matching distributor and carb, etc.?
I have a 9790071 YC block that looks like it is out of a 68' B-Body car (based on all the websites with code info). Your lucky though, your YT was out of an F-Body !!! and it made 330HP stock, mine was only 290HP stock...
I'm really just trying to catalog all of the engine data - when I repainted the block to the original color I made a point to take pictures of all of the numbers I could find.
If for some reason I lose my mind - I'll make you a good deal on my maching numbers block BronzeBird
here's what I have researched on my car so far 1968 Pontiac Firebird V8 Sport Coupe This car was the 42,217 made at the Lordstown, Ohio plant.
1968 Pontiac Firebird Coupe with Custom Trim Option The paint was Verdoro Green (1) The trim color and material were Medium Gold Custom Option Vinyl. This car has the Fisher Body Unit Number 15,949 built in the 3rd week of February at the Lordstown, Ohio plant.
ENGINE details
BLOCK VIN 28U142217 2 Pontiac 8 1968 U Lordstown, OH 142217 VIN Date Code A318 31-Jan-68
Casting # Year CID HP Main Notes 9790071 1968-69 400 330 2&4
CODE Car Year CID HP Trans RPO Car Block Cast YT F-body 68 400 330 Turbo400 L-67 1x4 9790071 Displacement 400 Casting # Year CID HP Valve CC Notes 16 1968 400 330 2.11/1.77 72 HO
