#188884 02/19/10 11:58 PM
Does anyone have any photos of how the hood tach wiring is routed? Finally hooked mine up and I'm looking to finish this project.
Any and all photos and suggestions will be appreciated!!!
Thanks,
Ron
Have you checked the manual. Pretty sure there is a picture of the wire routing for the tach.
I didn't have a factory tach but I used a factory harness in place of the junk three wire connection it came with. The factory harness has a plug for the wiper, a fuse for the coil connection and a ring for ground. I put a zip tie clip on the bolt studs because my light kept poping out.
Ground
Coil connection
