It's not easy. I would take the whole nose loose so you can move it out a couple inches. To do this you have to take off the nuts that hold the nose up. These are on the corner gussets. Then you should loosen the four 1/2 inch bolts that hold the nose assembly to the sub-frame. You can now pull the nose out away from the fenders. Remove the carriage bolts that hold the plastic headlight surrounds in place. You may want to loosen the nuts that hold "bat wing" filler to help give you room to remove and reinstall the surrounds. Jim
