I need to obtain and mount a front license plate bracket on my '67. Can someone tell me how it mounts and what hardware I may need to buy in addition to the bracket itself? Thanks.
Just two bolts through the front skirt sheet metal.
You can use just about anything if you aren't picky.
Then the license plate mounts to the bracket with two screws into plastic bushings. Check to see if the screws and bushings come with the bracket. Some do, some don't.
