Does anyone have a template of the center subframe mount (a diagram with both holes, so I can make a plate)? I only need to repair the center mount steel, and I don't want to have to buy a whole set. Thanks
If no one has a diagram, does anyone know what size diameter the hole is suppost to be?
If you want, ill trace my replacement plates and scan it in when I get out of work later. Then Ill post it in here. But I believe the hole is 1 1/2" diameter.
Heres when I did my own. I had to do the middle and rear mounts.
