Apparently they look the same. I was told one is higher strength and the other lower strength. ie: one is flimsy, the other more ridged.
David
low pressure supposedly is easy to bend (by mistake even)...not as hard...I would`nt buy those....as they say ,you get what you pay for....arent they also a bit cheaper?
once installed (and left in place) they would be ok...but the "studs" you add speed nuts to are weak
