is there a way to tell if the front bumper on my 68 is an original or a repro ? It is bent but fixable , but I want to know it is an orignal before I spend the money to fix it.
I think some if not all the original bumpers were made in Canada (at least on the 67's they were) so you might see a made in Canada label some where on the bumper if original.
If you have two to compare, the repops are a LOT lighter than the originals. I do not recall ever seeing any markings on them.
I believe mine is original, it is also stamped "Made in Canada"
WITH YOUR HELP !, trying to put back together a factory 1967 convertible 400/TH400, softray glass, pw, ps, pb, ac, console, clock, safeguard speedo, remote and visor mirror(s), hood and trunk lamps, and custom trim options.(Rally II rims and hood tach had been added). THANK YOU ALL for any help, opinions, and/or advice. I'M GONNA NEED IT !
