OK...I'm starting to get mad. I had a leak from the right tail light housing into the trunk on my '68. So, I decided to change the gaskets. I replaced them yesterday and it still leaks (seems like it's worse)...any ideas? Is there some type of sealant that I can you to put around the housing?
Try the 3M flexible sealing caulk. It's how the factory sealed things like the blower motor housing. I get mine from Eastwoods.
