2) Disconnect the fuel lines at the rubber line between the fuel sending unit and the main body lines.
3) Disconnect the fuel sender wire and the fuel sender ground wire.
4) Unbolt the bottom strap bolts and drop the tank. It is very helpful here to have a helper.
Eastwood makes a gas tank cleaning/derusting system in case you decide not to pop for a new tank (about $200).
If you want to "hide" an inline filter, there might be enough rubber line to splice one in along the rear frame rails between the body lines and the gas tank. It would be tough to see there.
I don't know if you have any Gas Tank Re-Nu locations down there, but if you do, get a price from them. I recently had a tank relined, blasted and painted for $140. Hard to beat.
They normally paint a semi-gloss black, but if you hand them a spray bomb with the correct paint they'll normally shoot it.
