I read a previous thread about how to fix a "lazy" fuel door. I called Ames and the new spring is almost $40.00 with shipping! Hey... I don't mind throwing money at my toy, but does anyone else sell this spring?
Or does it work to try bending it?
Thanks,
Steven
Steven Mehr North Woods Laser Engraving 1968 350 Convertible, 4speed Muncie
bending is a very short term solution. it will loose tension again. mine finally broke after rebending several times, and i put the broken end in the slot. now it works. i prob'ly got lucky.
magnets are cheap. a new spring is the real solution though.
I just bent mine last week. It worked for me and is the best it's been since i owned my car.
David
Steven,i put a screwdriver in behind the spring clip and worked it towards me(out)until i found where it would close the door/sit properly.Inserted the driver through the top,pulled out a little,then up from the bottom,pulled out a little.How permanent it will be,i'm not sure.All i know is that it worked well for me!
David.
