#199408 06/02/10 10:19 PM
J Offline
Hi!
Working on a '68 Firebird with a 400 HO motor. When we got it the clutch spring components were rusted away. Ordered the replacement parts. Not sure how it goes together. No diagram with the parts. Did find one diagram but it's not too clear. Can anyone point me toward a better one or how to hitch this up?
Q
Q Offline
This is in the 1968 service manual:
J Offline
Thanks a bunch! That helps a lot
what part of the frame or engine does the front of the spring attach to?
Q
Q Offline
If I remember right, to a bracket on the subframe. I can go take a peek at mine.
It attaches to the clutch fork. You will see a small hole in the fork at the end.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
One end in the fork the other end.....?
Q
Q Offline
That spring attachment just prevents the assembly from rattling when the clutch is engaged. The return spring attachment is what he needs. On my GTO it's to a frame-mounted bracket. I can't get under my OHC car to see where it's attached, though I thought it was attached to a bracket on the subframe. For a V-8 car, it might be attached to the front starter support.
Your diagram is for a OHC 6. The smaller diagram shows the 8 cyl. This exactly how I found it off a 69 FB. The "return spring" to put the clutch back in neutral position is supplied by the pressure plate via the fork. Another spring to the frame would be weaker and redundant.
2006 Sequoia
202? Electric car
Q
Q Offline
This is the view I am used to on my GTO. Note that the anti-rattle spring is labeled (incorrectly) as the return spring. As you can see, it would not return anything. The return spring is the one located on the frame bracket to the left arm of the counter-shaft.
Q
Q Offline
And this is the big-car set-up, which looks more like the Firebird's type than the GTO. Same problem with the labeling of the anti-rattle spring:
Q
Q Offline
That's actually the correct way to wear out the throw-out bearing.
I stand corrected...
I found a diagram on YearOne catalog. It shows the setup for 67-69 & 70+.
It looks like a have a frankinstien 67-69/70 setup. There is a bracket that mounts on the frame for a spring.
2006 Sequoia
202? Electric car
classic industries has that frame bracket for $17
Vikki
Restoration Gallery
http://thefirstgensite.com
