This is very important we need to stop the spread of this disease.
Information about Gonorrhea Lectim
The Center for Disease Control has issued a warning about a new virulent strain of this old disease. The disease is called Gonorrhea Lectim. It's pronounced "Gonna re-elect 'em," and it is a terrible obamanation.
The disease is contracted through dangerous and high risk behavior involving putting your cranium up your rectum. Many victims contracted it in 2008...but now most people, after having been infected for the past 1-2 years, are starting to realize how destructive this sickness is.
It's sad because Gonorrhea Lectim is easily cured with a new drug just coming on the market called Votemout. You take the first dose in 2010 and the second dose in 2012 and simply don't engage in such behavior again; otherwise, it could become permanent and eventually wipe out all life as we know it.
Several states are already on top of this, like Virginia and New Jersey , and apparently now Massachusetts , with many more seeing the writing on the wall.
If you research it further you'll see Gonorrhea Lectim started because of people burying there heads in to much Bush. This risky behavior of to much Bush caused by rampant ignorance caused the disease to spread to other organs such as the brain. Votemout was first used in 2006 and so far has virtually eliminated the original vial strain of Chennybush.
Time is needed to build immunities from more severe strains of republibush. Once a system balance is reached between Votemout and leavemout only then can the system be immune so all parties can once again participate in uninhibited bipartisanship.
To use votemout incorrectly so soon after a Republibush or Chennybush outbreak only delays recovery from the original Gonorrhea Lectim strain.
I kinda miss all of Bush's bad grammar!
