Posts: 317 |
Does anyone know if the PCV valve went on the driver's side oil fill or on the passenger's side? My care has factory AC so some of the brackets for the AC unit run really close to the grommet on the passenger's side valve cover. Any help wpuld be GREAT. Pictures would be better!!
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
It goes in the valley pan in front of the carburetor, there should be a grommet there. If not they are readily available at most parts places.
Posts: 856 |
67s go in the vally pan behind the carb.None in the valve covers.
Hmmm...thought they were the same from 67 to 68.
Posts: 6,758 |
Someone probably installed the pan backwards. The front I think is correct for 350 & 400's don't know if 326 is diff.
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
Posts: 5,108 |
Cant install the pan backwards. Pre 68's had the pcv valve in the rear. Used a breather cap on the valve cover instead of a tube to the breather inside the air cleaner on 68's and up.
1 members (Dr. Drivability),
1,839
212
