Putting the t-cover and water pump back together is turning into nightmare. I installed the t-cover, but unfortunately I did not install the water pump onto the t-cover before installing the t-cover to the block. Now I am left with the challenge of installing the water pump onto the t-cover while the t-cover is on the block. The issue is with the 2 plates that sit inside the t-cover. I can not get these plates to sit still, thus can not put on the water pump. Any suggestions other than removing the t-cover?
You mentiooned in another thread that you have an aluminum waterpump...and in this thread that the plates won't stay in place...
Do you have a '69 cover and an 11 bolt waterpump? If so, I think you should only have 1 plate...Someone help me out here. Doesn't the '69 or later pump have a different divider plate set up than do the earlier 8 bolt pumps?
Jay68, I looked at some of your earlier posts. I think you changed your timing cover...
If you have an 8 bolt pump: 2 plates. I just redid mine this week. My plates almost "snap" into place into to timing cover. Are your divider plates excessively coroded/rusted? They may need to be renewed.
11 bollt water pump: the plate would bolt into place, along with the pump.
ALSO...if you haven't already done this...check the clearance between the impellor and the plate(s). It should be 0.060 MAX. If greater, get the hammer out and "gently" bend the center of the plate. There's a detailed thread on the PY forum regarding this under Heating and Cooling..."Chalk another one up for the cast impellor..."
