The mark 8 fans come with their own shroud, I beleive, and they are supposedly a near perfect fit to our stock rad. I don't have personal experiance with it. Just what I've read. Also I pulled a 2sp elec setup out of a escort(not sure if it's the same) and it fit pretty well. Had to fasten it to the top but the bottm of the shroud slipped into the orig clips if I remember right. Don't know the cfm on high speed.
What are you running for an Alt.? 50 amp pull for the fan is a lot! I was thinking of doing the same with the MK8 (read about it on PY) but then started thinking of what I'll be able to find for an Alt to support it.
I bought a chrome alternator rated at 100 amp with my march performance serp system, but actually produced just 59 when shipped.. so I had it rebuilt to 100 amp
I have to replace the relays tomorrow too, I'll let you know the (short term) results then
IMO the correct 19.5" clutch fan, ALL upper/lower filler panels, stock shroud, rubber fillers etc. will solve all "hot" issues on any FGF. Not too mention everything fits, works and looks nice...
I used the Flexalite 180 kit. 3300 CFM. fit the rad pretty good. came with adjustable switch,relay, brackets, etc. car has only been running for 2 weeks now but has not gone above 190 yet, even during 20 min at 2000 rpm in garage during cam break-in. to see pics of it installed go to bottom of this page
