14 X 7's should as that was the factory size used on Firebirds. Check the backspacing - it should be about 4 1/2 inches.
BUT, what do you have up front? If you have done a disc brake conversion 14 inch wheels won't work and if these Rally's are off a 4 drum car and you have factory front discs - chances are they won't fit either.
The only way to check out the latter is to post the 2 letter code on the face of the wheels right next to the valve stem opening.
