I've got my PHS docs, does anybody know what the follow codes mean? 75Y / 76T / 77X. Also, her rear end has the following #'s stamped. 9792977 and below that is F057. Thanks!
PHS usually highlights the options you have and they also give you a sheet with the codes on it. One of the pages also tells the rear end ratio. F057=June 05 1967. 9792977 is the 67 casting number. Jim
I'll have to look up some info and see if I can find any of the codes... but off hand I believe that the 70's #'s on the build sheet are trim options? And the last looks to be a date code of June 5th 1967.
Is there a two letter code that you can find on the rear end axle tube?
I've looked all through my PHS docs - can't find anything with those codes on it, unless I'm blind and I'm reading right over it! Thanks for the rear end info
