Boy, these Pontiac engines are getting more puzzling by the day!
On the rear oil pan seal for a 68 400, the only one that fits around the main cap is the one that has the five nibs sticking out. What do I do with these?
The instructions aren't making any sense. They say this particular gasket for 59-71 doesn't have the nibs. The other, for 72-76, has two nibs and a center cone-shaped nib. It also says the 72-76 is called the 1st design.
My oil pan doesn't have slots for these nibs. Do I cut them off?
it also should have come with a cork , or rubber strip gasket that has no nibs it will fit in that area. if so use it and seal it to the oil pan with rtv.
Early engine blocks have a groove in the rear main cap that holds the cork gasket.
This groove was eliminated in 72 in favor of the 3 nib design rubber gasket and matching oil pans. This design basically sucked and was replace in 76 with the "2nd" design 5 nib that suffered way less blowouts.
Unfortuately, GM still holds the patent on the 2nd design so all aftermarket oil pans are stuck using the 3 nub gasket.
Or yet another option, use the really nice BOP 1-piece oil pan gasket.
It ties all 4 separate gaskets together so there should be a lot less concern about leaks were the 4 gaskets meet (usually where wise Pontiac engine builders put a dab of silicone)
The side rail sections are reinforced with metal. The rear seal is a combo design that allows this gasket to work with both the ealier rear caps for cork gaskets and the 1st design with 3 tabs (just cut the tabs off for a early application).
Now it's starting to make sense. I'll have to check the set again to see if there is another "non-nibbed" gasket.
The 5 nibbed gasket seems to fit. If this is all I have available, I should be able to cut them off and use a little RTV on the surface?
OK, I found the cork gasket. I was looking for rubber. (Another Chevy mindset) It seems a little too long, but the instructions say to use an adhesive to hold it down. I think it's long to compress fully into the pan groove, correct?
I'm still wondering if the 5-nibbed rubber one might still work, if it stays in place.
Now, I just discovered that the gasket set included two right side gaskets, no left side! So, I went and bought a pan gasket set. I'm not going to wait another week before the machine shop can get another set in!
The BOP 1-piece gasket is a "godsend". It really DOES "work". It fits all three "designs" (the cork strip is far and away the BEST of the factory designs).
I posted a procedure for this on Bill Boyle's site (pontiacstreetperformance.com) where you asked the same question. I have recently sent Bill an "article" I wrote concerning "sealing up" the whole Pontiac engine, and what pitfalls to avoid. He has not yet put it "up".
Cudos to Wade @ BOP. We talked to Felpro about 6 years ago about making us a 1-piece gasket. They said if they could sell 100K a year, they would "tool up". No chance of that... So Wade "bit the bullet" and is now supplying a choice piece, and for only a few dollars more than Felpro's BBC and SBC offerings.
BOP Engineering. You will find them via your favorite web browser.
