I bought a few a while back how many do you need I have the bolt's you can get the washers unless you have to have correct the i have a couple originals that need cleaned up! thank you Bil speer 520-490-9097
I need both of them. How much do you want and how would you like payment ? Are the washers anything special or can I just use regular flat washers ? I don't need it to be correct, just work.
All I had on my project were the bolts, so I had to use regular hardware store flat washers. They caved in due to the torque, so they definately need to be a hardened washer.
Vikki's site shows two lock washers under each bolt. One is listed as "1/2" Heavy" Not sure what they look like but I think they need to fairly large to cover the slots in the mounts.
I don't have my calipers or micrometer with me, it's at work. Using a tape measure they look to be approvimately 1/8" thick. Outside diameter is approx. 13/16". If you need a more acurate dimension I can bring home my calipers on Monday night.
